Tail Light Connector
Irdz
4.7 V8
Hi everyone,
I had to recently replace my tail light assembly and in doing so the connector got damaged and no longer latches properly. I'm trying to find a replacement to fix it, however I can't find it. If anyone knows the part number and where to get it, I'd greatly appreciate it.
hunterdan
SE PA
2019 classic
You'd probably need the body harness from ram or go to a junkyard and cut a few of them off.
Biker
diesel
I just cut the wires on mine and used wire nuts.
Brian2081
Weatland Michigan
Until you can replace plug, can you run a small zip tie around the plug and under the latch to help keep it lock on ?
