Tail light issue
Oefootball_70
OLATHE
I had the blinker go out on me. So I swapped bulbs, not the bulb, so I ordered a circuit board. and guess what not the circuit board. What in the world could be making my passenger side blinker not work but nothing else???
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Could be the switch In the column. I would check that.
Sent from my ADR6350
Oefootball_70
Oefootball_70
OLATHE
Also, my "light out" dash light is on. It still blinks my headlight passenger blinker. So i Don't think it is the column piece. I don't think.
05singlecabHEMI
Lilburn,GA
Did you check the blinker fluid? Sometimes when its low itll only cause one light to work... LOL.
i would try and test the voltage going to the blinker. If you dont get power then its gotta be a fuse or wireing problem. Also try out the hazard lights and see if that works.
Oefootball_70
Oefootball_70
OLATHE
Ill check hazards, but I don't have a volt meter. So I can't really check voltages. I did swap circuit boards and the same issues arose on the "working side" so its definitely wiring or relay issue on the passenger taillight.....
Saleen5150
