TB Ground....
truckin151
2013 sport
So far NOT impressed. Just wanted to check the idle for right now while parked to see what it would do.... result... zipp zero nada nothing.
Pre-Ground:
[yt]qMWuQ2Ir8IU[/yt]
Post-Ground:
[yt]BvQi7vhWOio[/yt]
Going to be out running around tomorrow and Sunday so I'll put it to the test. If it gets rid of the surging around 15-20mph I'll be happy, if not then it was a wasted 15min.
NWRQC
Curious to hear your thoughts after driving around a bit.
T
truckin151
2013 sport
Well more than likely its a cam/tune issue but I was hoping after hearing all the good things about this mod that it would help smooth it out..... Time will tell I guess
UberRam
Did you reset the PCM? I think most people say they noticed the difference after doing that.
Hammer_Z71
I didn't have to reset my PCM, nor do I see how resetting the PCM will effect a simple better ground.
I grounded mine really to disprove all the "hype" over the mod. Boy was I wrong! My 200+ RPM idle fluctuation steadied right out, dead steady needle now. I can also feel better throttle response, not night/day difference, but feelable.
The fact that it's basically a free mod (who doesn't have a piece of wire laying around?) and the 5-10 minutes it takes to do it, I would encourage everybody to try it. It can't hurt anything.
But yeah Ryan, I think grounding the TB to smooth out an after-market cam is a bit optimistic unfortunately...
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Ryan I think its in the tune and needs smoothing still.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I have the issue you guys are talking about only when I use a tuner. I feel more power with tuner but something about it my truck does not like having engine tuned at anything but stock. I have tried both superchips and Hypertech both make truck hesitate off the line just slightly as maybe the drive by wire lags. I notice more power for both tuners no matter the setting really just cant get past the lag then rocket pedal feel. Yes, I have reset pcm but that did not help. Only thing that helps is to go back to stock tune which luckily on the Hypertech I can still tune for tire size and other parameters even if engine tune is stock.
T
truckin151
2013 sport
If they are availible, try and find a ported throttle body. That will pep it up quite a bit
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Was that a cold start on them or full temp running? Looks like your idle is 800 for the midway point.
Hammer_Z71
I just got one guy's confirmation that it stopped his stalling at stop signs and red lights issue. '05 Hemi 4x4 stock except for Flowmaster cat back. Guy claims it was stalling about half the time at stops, has gotten worse over the past year. Dealer would experience it but never could fix it (after about four attempts). The guy says he could MAKE it stall 100% of the time if he stopped and cut the wheel hard in either direction.
Did the TB ground and it now sits at 700 rpm solid, turning the wheel will still drop idle a tad, but not enough to stall...
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
I did this last week at the same time as I re-installed my Ported TB which was giving me trouble. I switched out the knife edged plate with the one from my stock TB (that part of the TB is same diameter on both units).
Anyhow did the Ground mod at the same time (10 Guage) and attached it to a fender bolt ground behind the stock Air Filter Box.
So the ported TB works great now, better response, better shifting, and no more part throttle drivetrain "Bucking".
I think the ground is helping too as my Idle needle has no more bounce at all or roughness which I tend to experience during warm-up. First day I had some driveway jumping but I think the computer was still learning (did TBPS reset too).
I believe this mod helps, Guys. Perhaps I should have tried it alone before the TB swap to be 100% sure.
Probably won't make a difference to the Ground mod, but I am going to switch up to the 91 SC Tune this weekend after I ditch my Tail-pipes and dump the Magniflow in Preparation for a 1" Body-Lift.
So take this as a Modded Truck...Yes...to...maybe.
Deviate
St. Augustine, FL
2005 4x2
So the verdict on this is still that it won't have any effect on us 4.7s huh? While doing my stereo install I had the battery disconnected for a while which essentially reset the PCM. My idle smoothed out after that, but we haven't had any cold mornings here lately either so that might have something to do with it.
T
truckin151
2013 sport
When I had my ported TB, I got it first with the knife edge, and I hated ever moment driving with it, the sensitivity was just to high. Tap the gas and jump 10ft forward, made driving home in rush hour a royal PITA. Swapped the plate back and it worked like a charm.... until I cammed and tuned it, but thats another story.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Yes I remember you had said that about Your TB way back but luckely I never had real big jumps like you, just the Lightning Bolt into Limpe Mode.
Ricky91
