Teeing fuel line to empty fuel.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
A less expensive and labor intensive approach is you could use an AN bulkhead fitting on top of the gas tank and connect a 3/8's ss tube 3/4 down into the tank and simply connect an inline pump. This would suck out all but the last 1/4 tank or make the tube as deep as you want. This is a variation of how I originally set my OEM tank up and I used the tube as a return line directing fuel to the basket. I have a picture of the tank if interested I can post it.
drittal
E. Montana
The gas tank dilemma is one that doesn't have a single answer. It appears the states have different regs. Some limited to 6gal cans, some 8, some allow up to 119g with no placards, hazmat or cdl.
T
Totesmygoats
No, it's federal regulations. Some state are more restrictive, they cannot be less.
T
Totesmygoats
I use -8AN braided fuel lines with a pump that's rated for 300lph@60psi. I also have a momentary toggle switch on the dash to prime fuel rails. I mention this as it sounds like something close to what you are looking for. It would be easy to install a tee and ball valve to work as you want. You can price everything you need at Summit or Jegs.
Yea that's essentially what I want to do, just without new fuel lines, want to find a place in the oem system I can safely sneak a tee into. Might just end up pulling the line off the fuel rail or somewhere close, but I was hoping to avoid being sprayed each time (hence the tee).
00R/T
CT
If you depressurize the system first then you don't have to worry about spray. I've drained a tank many times using the fuel pump. I generally will pull the fuel pump relay, run the engine until it dies, unthread the schrader valve from the fuel rail test port and then put a piece of hose over the test port. Then I just jump the pump relay and run the tank down.
