Temperature specific rattle?
limechallenger
South of The Motor City
2014 Ram 4x4 Sport regular cab
I've got a 2014 Ram regular cab sport 4x4 with a very annoying rattle in the rear when I go over bumps in the road. Sounds like a loose shock, but I just replaced those. Heres the strange part, it almost sounds like metal on metal when its below 40 degrees outside, but today it was almost 50 degrees and the rattle seemed to diminish considerably? Any ideas? I' m gonna install new rear sway bar links the weekend, just because they are cheap! Any advise will help!
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
Did you torque the shock bolts to 100ft/lbs? That's what they call for.
Loudram
Navy Badge
South Jersey
Hemi 6.4L
That was the obvious thing. Wheel well liner lose or out of place, hitting something? I know you said maybe metal on metal sounding but it's worth a look.
Loudram
Navy Badge
South Jersey
Hemi 6.4L
The only other thing I can think of is get the bed rocking back and forth and up and down to try and isolate the noise. It could be a hundred things.
bigdodge
Check rubber bushings everywhere. The rubber is contracting in the cold weather and allowing something to move more. I just replaced body mounts for this. Control arm bushings, sway bar bushings track bar could also be an issue. Shocks if cheap can very in size the n the ends. Some may be too narrow and u will have to over tighten them a lot. Lots to check but shouldn't be hard to find with a big day jumping in the bed.
pedersen_tim
US
Check your parking brake cable guides. They rattle/squeak against the hangars they pass through
