The Fattest Tires
Dingalinger
minnesota
Hi, I just put a 6 inch lift on my 14 1500 and I am looking to get some bigger tires and I dont have enough money to afford both rims and tires so I am going to stick with my stock rims for now and just put some bigger tires on them but I am having trouble deciding what tire width I want to put on, ideally I want 12 wides but is it okay to put 12 wides on an 8 wide rim?
Daw14
South Florida
Tire stores list what will fit, look at a few websites to get some ideas, as in discount tire,tire rack,etc.
LeesEvoX
Houston, TX
Hemi 6.4l
Whatever tire you like you need to look at the manufacturers specifications. There they will list the recommended minimum, and maximum wheel width for any given tire size.
For most A/T tires in 12.5" wide the manufacturers actually list 8.5" as being the minimum width for your wheel. However, loads of people have installed a 12.5" tire on a 8" wheel with no issues.
It depends on your tire shop. For example. Discount tire can sometimes be a stickler on mounting the tires if your wheel doesnt meet the spec.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
285/60 is a good main sized tire that is priced well. Its a 34x11 when you get into odd sizes to push limits it often pushes your wallet too
Dingalinger
Dingalinger
minnesota
well I know I am going to put 37s on but im just trying to find a good width to do it with
Brian2081
Weatland Michigan
Dingalinger, the problem with going to the big chain tire shops is the company computers will not allow the store to install tires with a minimum width that is greater than your 8.5 rim width. I know I tried with discount, bought my tires there, the manager is old school like most of us and in the past before the nanny computers would install them no problem.
You will need to find a reputable smaller shop that can and will do it.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Nitto makes a 37x11.5 you can get away with 12.5’s too but may need to run spacers. That would depend on which wheels you have and their back spacing.
RAM DRVR
Mid left coast - Oregon
CTD
My 12.5 x 35's fit well on my stock rims. I have a 4" lift with some rubbing on the front at steering lock.
