Third brake light help
dodgeman2007
New Oxford, PA
2007 1500 Thunder Road Quad Cab 4x4
I have a 2007 dodge ram 1500 I just put a truck cap on it and i'm trying to hook up the third brake light. I hook the hot wire to the brake light wire on tail light wire on the truck. But that wire also controls the turn signal. when i push the brake it works but when i turn the turn signal on the third brake lights blinks. Just can't get it to work right. Hope hope someone can help me out Thanks.
HemiBabe
DFW
Welcome to RF!
I'm sure someone will chime in shortly
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
The tail should have 3 wires......try the other one ;)
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
It does have three wires, the only problem is its a ground, a turn/brake, and a running light. To OP: The only way to make it work with just the break lights is to run it to your 3rd brake light. The 07+ lights are a pain to wire up any aftermarket brakes or light bars.
D
dodgeman2007
New Oxford, PA
thats what I thought really don't want to do that. I like to keep all the wires hidden.
Saleen5150
