mowin
- Mar 1, 2014
- 462
- 152
- Location
- upstate ny
- 2017 3500 SRW
- 6.4 hemi
I installed the fifth wheel prep in my '14 3500. I cant belive how simple it was.
Kit contains the 4 outer puck components, but not the center goose neck puck. Not sure if it was available or not. The instructions list this kit for 3500, not sure if it fits the 2500.
First step was to loosen bed bolts on driver side, and remove bolts from passenger side. Lift and block passenger side of bed and place the cast piece in the pockets on top of the frame. Fasten with two bolts for each peice. Repeat for drivers side. Pic shows the pockets where the cast pucks go.
Map out in the bed where the 4, 3 3/4" holes need to be cut, install the trim pieces and caps, and your done. Took me around 3 hrs. I took my time and triple checked my measurements before drilling the holes. I had a 3 5/8 hole saw, and that worked fine.
