Thanks, T2 it is.
This^^^^^^^^Do some research on people using the new one. It’s a really new product and diablo has a track record of being glitchy before. I’ve seen some posts in different forums with people complaining about them. You can normally find a used t1000 for around $300 that’s still in great condition. It’s worth some time of research before you dump $600 into it
I Bleed Ram Trucks
Tuner first, then gears. You'll need the tuner to be able to adjust your speedometer for the gearing.
If you have the diff open doing gears might as well pull the trigger on LSD while you are at it. Most of the labor cost of installation is associated to disassembling and reassembling the rear end.
Better save for gears and lsd
Just bought an unmarried trinity. Lol.
I will buy something else to monitor with...saw one from a company called Edge that looks cool.
The Trinity does monitor. If you want to datalog real air/fuel. Get yourself an Innovate Motorsports LC-2 snd the plug in that goes to the trinity.....Better save for gears and lsd
Which pillar pod is that? Did you have to space the trinity out a bit for it to fit?You did buy a Trinity? They monitor, the T2 was just the newer version of it. I use the t-1000 and use the gauges all the time
I Bleed Ram Trucks
Thanks. Yeah not sure how different the 3rd gen ones are. Thats cool it fits, my jeep i had to shim the trinity adapter out a bit for it to fit. Was trying to figure out if i could do that with the Ram.I think it’s the auto meter pillar from from Moes. It’s a 3rd gen Ram, idk how different the newer ones are. I just bought the guague pod adapter for the trinity and it fit right in. The other gauge pods around it make it a tight fit but it still points in a good direction
I Bleed Ram Trucks
