thought ram was slower than should be..
chrisp2493
Always Modding
Warren, OH
392 Hemi
Yeah unless your dealer tech pulls down the tranny and notices the convertor is slightly different color, there’s literally no way for them to tell the stall is different other then doing a flash test while driving the truck. And they more then likely will never notice the gear ratios unless you put in an aftermarket limited slip as well. If you are stuck worrying about the warranty, then you’re stuck with a slower stock truck and nothing you can do about it. If you actually want a fast truck, then cam/stall/gears/tune and enjoy. Not much else can be said
I Bleed Ram Trucks
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Thanks, ya'll.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Have the dealer put the gears in, I would think that would keep your warranty.
Gears are going to make a HUGE difference on that truck with the transmission being gear that high.
I would do 4:56s like he^^ said
chrisp2493
Always Modding
Warren, OH
392 Hemi
Thanks, ya'll. Sounds like gears and a torque converter are good ideas.
How would they notice LSD? Not a smartass question, genuinely curious.
Some guys like to use a different differential locker that’s stronger then the stock LSD, and especially if they have open gears to begin with. If you changed out the locker it would be pretty obvious if they opened the diff
I Bleed Ram Trucks
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
The unfortunate part is that I drive 45 miles a day on a 70mph highway. What will that do to my RPM's, or engine life?
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
I have never done gears on a vehicle...how big of a difference are we talking with gears and/or torque converter? 1/2 second in a 1/4?
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Well its going to take your rpms up at hwy speeds for sure.
But you can't have everything, good mileage or good power its always a trade off.
Maybe 4:10s would be better alittle more middle road for you.
Gears will make a huge difference on your yruck.
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
All this money
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Pedal commander should finally be delivered at work for me to pick up monday.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Tuner, Gears, Tq Converter, and Longtube headers. Those are the 4 best mods you can buy for any 5/6sp Ram truck.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Bang for buck, I would do the tuner first. Then gears, then tq converter, and headers last.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Yes and when you do the gears you will be able to spin the rear tires so do the lsd at that time.
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Thanks, ya'll.
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Can't tell if the newest model just added a big screen, or if there are additional reasons to get it over a different model.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Tuning is identical between the I3 and the T2...just comes down to whether you want the monitor or not.
8675309
Southwest
2012 RCSB 2WD 6sp
HEMI 5.7
Thanks. Since there is no monitoring on the I3, I still wouldn't know my tran temps and whatnot. I have the ST, so I only get oil temps but nothing else....am wanting to be able to see trans temps and coolant temps and whatnot.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Then you would want to go with the T2
JustinRam1500
