throttle body 2004-2005
Hemiorange1969
Canada
I have an 04 Ram with 5.7. I just purchased a new throttle body but it is for an 05. From what I have read the only difference is a slight change in the plug, all wiring is the same. I can verify that the 05 will not plug into my 04 harness.
Are there any adapter plugs or any modification I can make to get it to fit or is my only option to cut out and splice in the 05 plug?
Hoping someone has done this mod.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
You are correct the only difference is the plug key. I changed to a 05 plug and have no issues. (BBK 90mm)
H
Hemiorange1969
Canada
did you splice in an 05 plug or were you able to modify the pre 05 to fit?
Thanks
Redtruck-VA
Virginia
At the time I spliced in a 05 plug. Since then I have cut the keys out of plugs that didn't fit without issue on O2s. So I'll say take a close look at it to see if it can easily be modified or pickup a 05 repair plug.
rockyj69
