Throttle Body Cleaning
ZakkBaker
FTW, TX
5.7L HEMI
I want to clean my TB but am not sure if I even need to? I just want to start doing more stuff to my truck and this seems like a good place to start, after my K&N CAI. What's the best way to clean it, I wouldn't wanna mess anything up. I saw TB cleaner spray at Pepoys, didn't buy it though bc I figured I'd wait and ask Ramforum :) are all sprays the same?
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
As long as the TB cleaner is not chlorinated you shouldn't have any problems. Chlorinated cleaner will damage the electronics.
SmokedRam
Zephyrhills, Florida
He can use reg throttle body cleaner on his 4.7 throttle body.
First thing to do is disconnect the battery
Anyway, disconnect the throttle body linkage, disconnect the throttle position sensor and the idle air control valve.
you'll wanna remove the throttle position sensor and set it aside, then remove the idle air control valve and set it aside.
Remove the throttle body from the intake, clean it, use a tooth brush for the really dirty spots, set it aside and let it dry.
Then clean the idle air control valve, I have a write up on how to do that in the DIY section.
Make sure everything is dry, reattach everything. reconnect the battery and done.
ZakkBaker
ZakkBaker
FTW, TX
5.7L HEMI
Alright thanks y'all! Ill read those DIY write ups :)
Notsobroke
I just cleaned my throttle body and IAC , they were filthy!!! I didn't notice any real change. I did see that there was some amount of wet oil. So i went ahead and did the pcv for cheap insurance.
Are people running open breathers on their engines?
ZakkBaker
ZakkBaker
FTW, TX
5.7L HEMI
I bet mines filthy too, dont think its ever been done lol. I guess it's just good for the health of the truck :p
Notsobroke
That's what i figured I only have 66k on mine but the service this truck saw before me was oil changes and basic stuff only. I know i usually bypass the breather but was wondering if they have catch cans for these 4.7 trucks
SmokedRam
Yeah there is, but I'll have to get the parts list from my friend. You need to purchase a new oil fill spout without the PCV nipple, then run it some funky way...
Sundown
