Tick sound
Plop92
Southern Idaho
V10 8L
Was driving down the road and heard a tick sound seems to happen when im just accelerating and keeping a costent speed anything I need to worry about
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
If it sounds almost like an exhaust heat shield that is loose and rattling, but only the lower frequencies while coming from the center of the vehicle, it's most likely your plenum. Mine made that noise, at first I thought it was just some loose bolt or something allowing for some hot metal on metal action. Turned out to be my plenum gasket, so much for thinking it was already done. Since i've replaced the gasket, no more tick/pinging sound.
Just like you I only heard it under light accel, or holding speed. I thought it was suspension noise for the longest time until I caught it one day in drive at a stoplight.
P
Plop92
Southern Idaho
V10 8L
Would that be normal ware and tear
dudeman2009
Magnum 360
For these trucks, sure. It was and still is common for OEM plenum gaskets to go bad. Unless it was properly fixed by the previous owner or dealer, it is going to have the gasket break. The replacement isn't hard at all if you have the tools. I chose to service the valvetrain at the same time as I was already going to be working in the area. But that is not necessary, I just had some valves with out of spec valve lash to fix. I will say that pulling the valve covers made it easier to get my hands onto everything, not that it was hard before, it was just really easy after the valve covers were removed.
P
Plop92
Southern Idaho
V10 8L
Thank you looks like ill be buying me a Hanes book on payday lol thanks for the help
