I just had the heads redone on my 02 4.7 it has the dual over head canes how do i time it correctly any help would be greatly appreciated
This1. What are over head canes?
2. If you have double overhead cams then you do not have a 4.7; 4.7 is single overhead cam
3. If you do have a 4.7 with it's single overhead cam, you'll need these pages specifically (if you want the whole manual, it's in the service manual sticky)
I do have a 4.7 it does have dual overhead cams if it not a 4.7 then what motor is because everything on it says 4.7 either way my timing is off and how to get in time would be helpful i already have it tdc but my v8 on my sprockets are not line up at 12 o’clock so how do i got about it from there
I sorry for my confusion i have a cam per head i was under the impression that was consider dual overhead cam i have one cam per head on a 4.7 my issue is how do i get the v8 marks were they need to be my main chain is a tdc this is the only thing keeping my truck from going on the road
So basically my valve timing is off
02 ram 1500 4.7 valve timing is off i have it on Tdc how do i get the cam spokets to the v8 mark at twelve oclock for correct timing
And to be perfectly clear if i wanted someone to do it it would be in a shop hints the other reason I’m on here asking questions so no need for the disrespectful ness your coming off with question is if your not here to help then why are you even on the forum forums are created to help other no get all made cuz someone asking how to do something but hey sorry for take time away from you bud but if you didn’t feel like responding why did you
