tx1500ram
I have a 2012 ram 1500. I have recently replaced the TIPM (less than a week ago) and the fuel pump (however I had driven on the fuel pump with a bad tipm for about 1200 miles (Maybe that killed the new fuel pump?) My fuel pump now is constantly running even when the truck is off and only stops whenever I remove the M25 fuse. I was wondering if anyone else has had this issue and if they know what the fix is and if it's possible to fix myself. The truck will also have a crank but no start when first starting it after leaving it for a while. It will eventually start up after priming the key a few times.
