- Joined
- May 27, 2023
- Posts
- 1,730
- Reaction score
- 1,909
- Location
- Sthrn AZ
- Ram Year
- 2023
- Engine
- 6.4 Hemi
Although I don't foresee myself needing any in the near future, I have always thought it was a good idea to have a set "just in case"; especially for a 4x2 truck. I've only had to use chains 2 or 3 times in the past 30 years, so if I ever did need them the odds are it would be for light use and for a very short period. I just bought a pair of these and wondered if anyone else has used them and what their opinion is...Titan Diamond Alloy Square-link. I did get the LT as opposed to the HD version because I couldn't find the HD version available to fit my size tire, but with the minimal use I would ever expect them to be used for I think they will suffice.
I test-fitted them when they arrived and they're actually pretty easy to install once you get the chains hanging correctly. It's the removal part that can be a booger. You need to try to get them back in the same position (with the green link at the top) or you won't be able to get to the part of the cable behind the tire to unhook it.
