Tire PSI
Flryder
Bradenton, Fl
Hi, I have load range E tires on my Ram. The stock inflation pressure is 40 PSI. Load range E tires can go to 80 PSI to increase their weight carrying capacity. I tow a RPOD 192 that weighs (empty) about 3500 pounds and has a tongue weight of about 440 pounds. How should I determine how much to inflate my rear tires to?
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Correct way is to take truck to a CAT scale and get actual weight. Once you have the actual weight you can check TRA load tables for correct pressure to carry the actual load.
Sent from my SM-T350 using Tapatalk
JRS950
All over the great USA
Cummins 6.7L
This the best way to determine tire pressure. Excellent advice.
Quyonmob
Canada
Here’s a calculator to set your new tires to the same load capacity as the OEM door sticker tires. Great place to start the chalk test.
https://tiresize.com/pressure-calculator/
the differences are surprising, my results were (for an oem door sticker of P265/70/17 @ 40psi):
265/70/17 115 (notice no “p”) = 34psi
LT265/70/17E 121 = 47psi
this will ensure your new tires are inflated to carry at least the OEM GVWR.
joshhhh
