I'm no spring chicken with mechanical issues but tires aren't in my wheel house so to speak. My question is what size tire can I fit on my 04 1500 quad cab with 4X4 and it seems to have a body level on it. Suspension is stock. I don't mind a bit of rub when I turn to full lock as I rarely do so, I also have no problem removing the fender wells as I plan on fabricating custom ones out of diamond plate. I defiantly want a bigger diameter and with that I'd like to go up in width, I will use wheel spacers if need be. I'm also aware that I will most likely have to replace the rims to fit the new tires.
