Tire/rim offset opinions
R4z0r
Hi, I have a 2014 ram 1500, stock no lift or level.
I'm looking to run a 20x9 rim that has a +20 offset. Tires are a 305/55/20 (33tall 12.6 wide) or a 295/55/20 (33 tall 12.5 wide).
Has anyone run something like this, or know someone who has with no issues?
Thanks.
Cruizer
Ohio
2010 Sport 4x4 QC
Stock my truck has 20x9 and +19 offset with 275/60R20's. I believe if you go that wide you will need a spacer to clear the upper control arm. From everything I've read, the width of the tire is a bigger issue than the height. At least within reasonable height. I'm sure there are some guys running those sizes though somewhere here. :welcome:
Arctic-Rodz
RGV, TX
6.7L Cummins
What you need is 0mm offset wheels. that will look great (what im going with)
I have seen a lot of locals running M/T tires on the OEM sport wheel with no clearance problems.
smarsmar101
Waterford. CT
12.5 wide and you'll need spacers. Or 0/neg offset wheels so you're not rubbing.
jhicks1983
