Tire size for 3” front and 2” rear lift
Brandon Hyatt
Tampa Fl
3.6 L v6
So I have a 2015 1500 and I was wondering what is the most aggressive tire size I could run on 20” rims without rubbing. I have stock wheels and tires right now and I just need something to make the truck look a little bigger and better.
Triumphx
35x11.50 if you don’t want to run spacers on your stock wheels
6.7CumminsDrvr
The Dude abides………
Georgia
Check out manufacturer specs from their website. They provide the section width so you can see what size the tire will actually be. As a note, any tire that specs to 12.1” wide on a 20x9 factory rim will fit without spacers and without rubbing.
My 35 12.50’s spec out to 34.69” tall and 12.1” wide on a 20x9. On a 20x10 they spec out to 12.50”.........
Reactions: JB1
BOWERSFJ
Uniontown OH
Do you have a leveling kit on?
Did at one time ... Now have 4” lift with Bils ... When I had Bils at 2.1” I ran 285/60’s ... With you being 3” in the front, 295/60’s should be perfect
