Tire Size
clarktrxxx
High Ridge, MO
I have a 2024 Ram 2500 Laramie with stock rims and tires (285/60R20), will 35x11.5R20 tires fit without doing any suspension modifications?
Dean2
Near Edmonton
Existing tire size converted to inches is, 33.5X11.2R20
If you use the stock rims the new tires will fit easily being they are close to same width and only 1.5" taller, so effectively only 3/4" higher from center of rim at the axle. If you use an after market rim, make sure it has the same offset.
For future use, this makes it easier.
