Tire/Wheel Fitament Question
cdixon1
Hello All. I am the proud owner of a new 2016 white cc 4x4 with the stock 20 chrome clads and 3.21 gears with the 8 speed. like many of you the first thing i want to do is wheels/tires/level. I am set on the 5100's for the level. for wheels and tires i am leaning towards the method nv black in 18x9, 5.75BS, +18 offset. for tires i am leaning toward toyo AT2's in 285/75/r18 (34.8x11.2).
does anybody have an opinion if this will rub (with or without the leveling kit)? will i regret going this big of a tire with the 3.21's? expected mpg drop? i prefer not to have the wheels/tires to stick far out the wheel wells, which is why i chose the wheels with very close to stock specs. i have searched and searched, but would like if someone could confirm before dropping 2k on them.
thanks
quietpeen
2021 TRX
Hellcat
What level are you planning for the bilsteins. If 2.1 you wil rub. Better chance of no rubbing with 2.8
Edit: oops sorry I first read that as - 18 mm offset. With that size and with I think you should be good
C
cdixon1
Thanks for the response. Any thoughts to how that size tire will work with the 3.21 gears?
