Robeffy
- Jul 14, 2018
- 158
- 130
- Location
- Northern Ontario
- 2018
- Cummins 6.7 TD
Hi,
My 1995 1500 Ram 318 automatic was bought a few years ago, with 145000 km, about 90,000 miles.
The first owner's son overheated the tranny, and then it started to shift bad, a slipping shift, from 2nd to 3rd gear. Mileage is about 190,000 km now, around 120,000 miles.
I bought it, and discovered that if you ran it up to 3000 rpm, and backed off the gas, it would shift fine.
So, I changed the trans oil filter, twice, and drained out the fluid a few extra times, and every time I changed the filter and replaced oil, it shifted better, and better, and now it barely ever slips at all.
So, I plan on changing the trans filter again, adding more new fluid.
Do I leave the bands alone or try to adjust them, while the pan is off?
Do I check the trans oil pressure? I assume there is an adjustment of some type, and I wonder if a 25 year old tranny needs to be adjusted?
I pull a 4500 lb RV trailer now and then, a snowmobile trailer a few times.
I have a huge 11000 or 12000 btu oil cooler plumbed in, and a temp gauge, and it never gets hot anymore.
My guess is that some "gunk" was in the valve body and has slowly been working its way int the filter.
I also added a Mr Gasket oil drain plug to the trans pan, to make it easier to drain and replace fluid. If you get one, buy some extra copper washers, the one's in the kit just split while I was installing the plug.
Summary... dont touch the bands of pressure, leave it alone, or try to snug up the band, and play with the pressure?
