Torque Specs
Eddi310
San Antonio (Kirby), Texas
2010 Lone Star
Air fuel control banjo screw (in pump)--------------------------------9 ft lbs
Air fuel control fitting ( in head)-----------------------------------6 ft lbs
Alternator ground cable mounting to bloc----------------------------18 ft lbs
Alternator mounting to water pump inlet----------------------------30 ft lbs
Alternator pulley--------------------------------------------------60 ft lbs
Alternator support (upper)------------------------------------18 ft lbs
Battery cable ( negative) mounting to block----------------------57 ft lbs
Belt tensioner mounting----------------------------------------32 ft lbs
Block heater mounting---------------------------------------------9ft lbs
Cab heater hose clamp--------------------------------------------------35 in lbs
Cab heater tubing clamp mounting--------------------------------18 ft lbs
Camshaft thrust plate-----------------------------------------------------18 ft lbs
Clutch cover mounting to flywheel---------------------------------------17 ft lbs
Connecting rod (alternately tighten in 3 steps)
Step 1-------------26 ft lbs
Step 2-------------51 ft lbs
Step 3-------------73 ft lbs
Cooling fan mounting to fan clutch----------------------15 ft lbs
Crossover clamp (air)------------------------------------44 in lbs
Cylinder head mounting bolts
1- All bolts---------------66 ft lbs
2- long bolts-------------89 ft lbs
3- tighten all bolts----------- additional 90 degrees
Exhaust manifold------------------------------------------32 ft lbs
Exhaust outlet pipe-v band clamp----------------------72 in lbs
Exhaust pipe clamp mounting------------------------------------20 ft lbs
Exhaust pipe steady rest mounting to trans------------------50 ft lbs
Fan clutch mounting / fan hub (left hand threads)-------------42 ft lbs
Fan hub bracket mounting-------------------------------18 ft lbs
Fan hub bearing retaining cap screw---------------------------57 ft lbs
Fan pulley to fan hub-------------------------------------------------7 ft lbs
Fan pulley crankshaft----------------------------------------------7 ft lbs
Fan shroud mounting nuts----------------------------------------95 in lbs
Flywheel bolts------------------------------------------------101 ft lbs
Flywheel housing adapter---------------------------------------44 ft lbs
Front engine mount isolator mounting to mount----------------------80 ft lbs
Front engine mount through bolt-----------------------------------30 ft lbs
Front engine mount to block----------------------------------------44 ft lbs
Front oil filler pipe-access cover--------------------------hand tighten
Fuel banjo screw (in fuel pump)---------------------24 ft lbs
Fuel banjo screw (in head)-----------------------------------------18 ft lbs
Fuel banjo screw (in injector)---------------------------------------6 ft lbs
Fuel filter-----------------------------------------half turn after contact
Fuel heater assembly mounting------------------------------------24 ft lbs
Fuel heater ground mounting to intake manifold--------------------9 ft lbs
Fuel link fitting (high pressure)-----------------------------------18 ft lbs
Fuel low pressure supple------------------------------------18 ft lbs
Fuel pump drive gear (with pump unlocked)---------------------------------------------48 ft lbs
Fuel pump lock (bosch)-------------------------------------------------------------------22 ft lbs
Fuel pump mounting mount---------------------------------------------------------------18 ft lbs
Fuel pump solenoid------------------------------------------------------------------------32 ft lbs
Fuel pump support bracket----------------------------------------------------------------18 ft lbs
Fuel pump unlock (bosch)-----------------------------------------------------------------10 ft lbs
Fuel vent screw (in banjo)------------------------------------------------------------------6 ft lbs
Gear cover---------------------------------------------------------------------------------18 ft lbs
Gear housing - to - block------------------------------------------------------------------18 ft lbs
Injector retaining nuts---------------------------------------------------------------------44 ft lbs
Intake manifold cover---------------------------------------------------------------------18 ft lbs
Intercooler attaching bolts----------------------------------------------------------------17 in lbs
Intercooler duct clamp nuts--------------------------------------------------------------72 in lbs
Lift pump mounting------------------------------------------------------------------------18 ft lbs
Lifting bracket (rear)----------------------------------------------------------------------57 ft lbs
Main bearing cap bolts
Step 1-------------------------------------------------------------45 ft lbs
Step 2--------------------------------------------------------------88 ft lbs
Step 3------------------------------------------------------------129 ft lbs
Oil cooler assembly-----------------------------------------------------18 ft lbs
Oil fill tube bracket------------------------------------------------32 ft lbs
Oil filter-------------------------------------------------3/4 turn after contact
Oil pan drain plug-------------------------------------------------------60 ft lbs
Oil pan mounting----------------------------------------------------18 ft lbs
Oil pressure regulating plug--------------------------------------------60 ft lbs
Oil pressure sender / switch--------------------------------------------12 ft lbs
Oil pump mounting-----------------------------------------------------18 ft lbs
Oil suction tube (flange)------------------------------------------------18 ft lbs
Oil suction tube brace----------------------------------------------18 ft lbs
Power steering pump to vacuum pump mounting-----------------------18 ft lbs
Radiator hose clamp - upper------------------------------------35 in lbs
Radiator mounting nuts--------------------------------------------95 in lbs
Rear seal mounting---------------------------------------------7 ft lbs
Refrigerant compressor lines - flange mounting-------------------15 ft lbs
Refrigerant compressor mounting------------------------------35 ft lbs
Rocker lever nut-------------------------------------------- 18 ft lbs
Rocker support----------------------------------------------------18 ft lbs
Starter mounting--------------------------------------------------32 ft lbs
Starter battery (positive) cable nut----------------------------16 ft lbs
Starter solenoid nut-----------------------------------------------44 in lbs
Tappet cover / fuel drain line supports------------------------18 ft lbs
Thermistor-------------------------------------------------------18 ft lbs
Thermostat housing-------------------------------------------- 18 ft lbs
Throttle bracket mounting to mounting bracket------------------18 ft lbs
Throttle rod mounting to throttle lever nut---------------------7.5 ft lbs
Timing pin flange mounting------------------------------------44 in lbs
Torque converter access cover plate mounting--------------35 in lbs
Transfer case linkage bracket mounting / trans------------------30 ft lbs
Transfer case mounting to transmission-----------------------35 ft lbs
Trans cooler tubing mounting to oil pan flange-------------18 ft lbs
Trans kickdown cable bracket mounting / trans--------------50 ft lbs
Trans mount mounting to trans (manual)-------------------50 ft lbs
Trans mount through bolt mounting (manual)-------------50 ft lbs
Transmission mounting to engine----------------------------30 ft lb
Transmission oil cooler line connection------------------------40 ft lbs
Transmission oil cooler line flange----------------- 50 in lbs
Transmission oil to air cooler hose clamps-----------------18 in lbs
Transmission to clutch housing mountin--------------35 ft lbs
Transmission torque converter mounting--------------------35 ft lbs
Turbine housing-----------------------------------------8 ft lbs
Turbo compressor housing clamp--------------------75 in lbs
Turbo mounting nut------------------------------------24 ft lbs
Turbo oil drain tube--------------------------------------18 ft lbs
Turbo oil supply (both ends)------------------------------11 ft lbs
Vacuum pump mounting-------------------------------------------7 ft lbs
Vacuum pump to gear housing mounting-----------------57 ft lbs
valve cover---------------------------------------------------18 ft lbs
Vibration damper mounting----------------------------------92 ft lbs
Water hose clamps-------------------------------------- 35 in lbs
Water inlet connection---------------------------------32 ft lbs
Water pump mounting----------------------------------18 ft lbs
Water temperature sensor--------------------------------37 ft lbs
E
Eddi310
2010 Lone Star
Chassis Torque Specs
(4th Gen RAM)
Shock Absorber Upper Nut --------------------------------------------------------------40 ft lbs
Shock Absorber Lower Bolt -------------------------------------------------------------100 ft lbs
Shock Tower to Frame -------------------------------------------------------------------55 ft lbs
Lower Ball Joint Nut Initial Torque------------------------------------------------------ 35 ft lbs
Lower Ball Joint Nut Final Torque ------------------------------------------------------148 ft lbs
Upper Ball Joint Nut -----------------------------------------------------------------------70 ft lbs
Lower Control Arm Frame Nuts --------------------------------------------------------200 ft lbs
Lower Control Arm Axle Nut------------------------------------------------------------ 200 ft lbs
Upper Control Arm Frame Nuts --------------------------------------------------------120 ft lbs
Upper Control Arm Axle Nut ------------------------------------------------------------120 ft lbs
Stabilizer Bar Frame Bolt ----------------------------------------------------------------45 ft lbs
Stabilizer Link Axle Bracket------------------------------------------------------------ 110 ft lbs
Stabilizer Link Stabilizer Bar Nut --------------------------------------------------------27 ft lbs
Stabilizer Link Axle Bracket (Power Wagon)------------------------------------------ 110 ft lbs
Stabilizer Bar Nut (Power Wagon) -----------------------------------------------------110 ft lbs
Hub/Bearing Bolts -----------------------------------------------------------------------149 ft lbs
Axle Nut - 132 ft lbs Beginning Torque, Then Rotate 5 to 10 ~ Times With a Final Torque of 263 ft lbs
Track Bar to Frame (2500/3500 4x4) -------------------------------------------------200 ft lbs
Track Bar to Axle (2500/3500 4x4) ----------------------------------------------------200 ft lbs
Tie Rod End Nut ---------------------------------------------------------------------------55 ft lbs
ABS Assembly Mounting Bolts -----------------------------------------------------------11 ft lbs
ABS Assembly ABM Screws -------------------------------------------------------------31 in lbs
ABS Assembly Brake Line Fittings -----------------------------------------------------170 in lbs
Dynamics Sensor--------------------------------------------------------------------------97 in lbs
Wheel Speed Sensors, Front Sensor Bolt ----------------------------------------------190 in lbs
Wheel Speed Sensors, Bracket To Knuckle ---------------------------------------------60 in lbs
Wheel Speed Sensors, Rear Sensor Stud--------------------------------------------- 200 in lbs
ABM Mounting Screws --------------------------------------------------------------------53 in lbs
RWAL Module Mounting Bolts ------------------------------------------------------------11 ft lbs
RWAL Valve Brake Line Fittings --------------------------------------------------------170 in lbs
Rear Wheel Speed Sensor Mounting Bolt ----------------------------------------------200 in lbs
Brake Booster Mounting Nuts ------------------------------------------------------------21 ft lbs
Master Cylinder Mounting Nuts ---------------------------------------------------------160 in lbs
Reservoir Retaining Screws ----------------------------------------------------------------6 ft lbs
Caliper Bleed Screws ---------------------------------------------------------------------14 ft lbs
Caliper Mounting Pins, Front -------------------------------------------------------------24 ft lbs
Caliper Mounting Pins, Rear --------------------------------------------------------------22 ft lbs
Caliper Adapter Mounting Bolts, Front (1500) -----------------------------------------130 ft lbs
Caliper Adapter Mounting Bolts, Front (2500/3500) -----------------------------------275 ft lbs
Caliper Adapter Mounting Bolts, Rear (1500) ------------------------------------------120 ft lbs
Caliper Adapter Mounting Bolts, Rear Upper (2500 and 3500) ----------------------163 ft lbs
Caliper Adapter Mounting Bolts, Rear Lower (2500 and 3500) ----------------------190 ft lbs
Junction Block Bolts, Front (1500) -------------------------------------------------------14 ft lbs
Junction Block Bolts, Rear (1500) --------------------------------------------------------18 ft lbs
Junction Block Bolts, Rear (2500/3500) ------------------------------------------------7.5 ft lbs
Brake Pedal Assembly Bracket Bolts (1500) --------------------------------------------23 ft lbs
Brake Pedal Assembly Bracket Nuts (2500/3500) --------------------------------------21 ft lbs
Support Plate Mounting Bolts/Nuts (1500) ----------------------------------------------75 ft lbs
Support Plate Mounting Bolts/Nuts (2500/3500) -------------------------------------150 ft lbs
Brake Line Fittings, Master Cylinder -----------------------------------------------------14 ft lbs
Brake Line Fittings, Junction Block (Both) -----------------------------------------------14 ft lbs
Caliper Brake Line Banjo Bolt, Front -----------------------------------------------------20 ft lbs
Caliper Brake Line Banjo Bolt, Rear ------------------------------------------------------20 ft lbs
Brake Hose Bolts To Frame, Front ------------------------------------------------------7.5 ft lbs
Brake Hose Fitting ------------------------------------------------------------------------14 ft lbs
Parking Brake Pedal Assembly (1500) ---------------------------------------------------18 ft lbs
Parking Brake Pedal Assembly (2500/3500) -------------------------------------------14 ft lbs
Hub/Bearing Bolts (1500) ---------------------------------------------------------------120 ft lbs
Rotor to Hub Bolt, Rear (2500 and 3500 DRW) ---------------------------------------114 ft lbs
Extension to Rotor Nut, Front (2500 and 3500 DRW) --------------------------------128 ft lbs
Hub/Bearing Bolts, Front (2500 and 3500 4X2) ---------------------------------------130 ft lbs
Pitman Arm Gear Shaft Nut (2500, 3500) ---------------------------------------------177 ft lbs
Drag Link to Pitman Arm (2500, 3500) ------------------------------------------------100 ft lbs
Drag Link to Tie Rod (2500, 3500) -----------------------------------------------------100 ft lbs
Drag Link Adjuster Clamp (2500, 3500)------------------------------------------------- 40 ft lbs
Tie Rod End to Knuckle (2500, 3500) ---------------------------------------------------78 ft lbs
Tie Rod End Adjuster Clamp (2500, 3500) ----------------------------------------------40 ft lbs
Stabilizer Bar Link to Axle (2500, 3500) -------------------------------------------------50 ft lbs
Steering Damper to Axle or Linkage(2500, 3500) -------------------------------------75 ft lbs
Steering Damper Bracket U-Bolt Nuts (2500, 3500) ------------------------------------45 ft lbs
Track bar to Axle - M16 fastener (2500, 3500) ----------------------------------------200 ft lbs
Track Bar to Frame - M16 fastener (2500, 3500) -------------------------------------200 ft lbs
Lug Nut 9/16 X 18 with 60° Cone ------------------------------------------------------130 ft lbs
Lug Nut 9/16 X 18 with 60° Cone (2500, 3500 - SRW) -------------------------------140 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (3500 - DRW) ----------------------------------145 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (4500, 5500 - DRW) ----------------------------148 ft lbs
Spare Tire Winch --------------------------------------------------------------------------15 ft lbs
Jounce Bumper Bolts ------------------------------------------------------------------21.5 ft lbs
Shock Absorber, Lower Nut/Bolt --------------------------------------------------------100 ft lbs
Shock Absorber, Upper Nut/Bolt -------------------------------------------------------100 ft lbs
Spring Clamp U-Bolt Nuts --------------------------------------------------------------110 ft lbs
Spring Front Nut/Bolt to Frame ------------------------------------------------------254.5 ft lbs
Spring Shackle Nut/Bolt, Upper/Lower -------------------------------------------------160 ft lbs
R.L.K.
Bristol , Tn.
Awesome ! Thanks guys !
xWAKESx
Nebraska
What’s the specs then for the muffler clamps? 20 lbs?
acolic
Hamilton
Anyone have the torque specs for:
BW 44-44 Transfer case fill and drain plug
Rear diff drain plug
Front diff fill and drain plug?
I have a 2014 sport and I just changed these fluids and did a hand tight of the plugs. But would like the actual torque spec if available.
Thanks
