Tow/Haul button
Chrismb5.7
Dandridge, TN.
So the tow/haul button on the end of my collum shifter is gone... Anyone know where I can find another one?
lharrell79
I don't think the button is sold by itself. You have to buy the entire shifter column. You might try a junk yard.
HemiLonestar
Navy Badge Coast Guard
MD
You need this: https://www.ebay.com/itm/04-05-Dodg...423708?hash=item5b531cda1c:g:6-MAAOSwzE5cYabG
You can either swap shifters or the button will actually come off to swap over (which you'll still need to pull the shifter to do anyway). If the pins that go to the bottom of the button are still intact and you can get a little slack in the wire, you can swap the button over without having to pull your shifter.
