Tow mirrors
atomicglock
Hemi 5.7l
Hi, all:
Just bought a used 2014 2500 with the 5.7l. The truck came with the small "flag" type mirrors and I need tow mirrors. I Binged them and new ones on OEM websites are going for over $500.00, whereas ebay is selling aftermarket ones for just around $270.00 to $300.00. Any of these any good or should I try to get them from a junk yard? Thanks
1ATony
hemi
We carry tow mirrors for your Ram truck. If you would like to reply back with the features that your mirrors currently have, I can see if we can match a set up for you.
Tony
avolnek
2015 Ram 2500 CCLB
1A auto is the only way to go! Their customer service is far superior to most places I have dealt with. I had an issue with the connector of one of the mirrors i ordered. I contacted them and they had me a new one the next day. Not much else to say about their service other than they rock.
Their product (mirrors in my case) are of very fine quality. no they aren't factory but they are a very high quality. the materials look great, the lights work and are bright and the mirrors themselves dont vibrate driving down the road!
Do note though that you will most likely have to go to the dealer to flash the sales codes on board of the truck to allow the mirrors to operate correctly.
spoon059
Just north of Washington DC
6.7 CTD
Correct... otherwise the truck won't know if you are flipped up or not and it could be a pain in the neck trying to adjust the mirror when the movements are 90 degrees off!
Just bear in mind that starting around 2013 that Ram put the exterior temperature probe in the mirrors. Don't buy a 2012 tow mirror set and think they will work on the 2013+ models.
firemedic10584
Central Fl
I'll second using 1A Auto for new mirrors - I purchased a set of aftermarket (ebay) mirrors once for my dad's '05 and the vibrated so bad at 40+ mph that they were not even usable at that point. I was hesitant on buying mirrors for my '15 truck that weren't OEM just from past experience. But, 1a-Auto's mirrors are OEM quality and I have not noticed any vibrations and I've had the truck up to about 75 mph with the new mirrors. Highly recommended.
A
atomicglock
Hemi 5.7l
Tony
Hi Tony,
Sorry it's taken me so long to reply. My current mirrors are, as I said, the small flag type ones with power adjust and heat. I do not see any lights nor blinkers on them anywhere. My truck is a black 2014 2500 SLT crew cab short bed. Thanks.
1ATony
hemi
Hi Tony,
I checked on these for you, and we currently only have them with power, heat, turn signals and puddle lights.
If your truck didn't come with all of these features from the factory, I wouldn't recommend adding them on.
Thank you for asking,
Tony
DRkNESS
South Jersey
Hello Tony. I have a 2011 Ram BigHorn with puddle, heat, blinkers, and power. I would like a set of tow mirrors that are plug and play for my truck. Can you post a link for your site for these so that I can pick up a set ? If you don't want to clutter this posting, please pm me with the needed info. Looking forward to doing business with you real soon. :)
A
atomicglock
Hemi 5.7l
Tony
Any suggestions as to the best place to find a set of tow mirrors?
A
atomicglock
Hemi 5.7l
Bump.
I've tried finding tow mirrors at carparts.com with no luck so far. What about add on mirrors like those from ****?
11400 Dodge Custom Towing Mirrors | **** USA, Inc.
bigolayne
Springfield, MA
Tony
Why wouldn't you recommend adding them on? My 1500 didn't come with turn signals or puddle lights either but I purchased the lights from you and had the dealer flash the codes and everything works great. Just curious as to why not for him...
AustinB
Banned
San Diego, Left Coast
Wonder if some trucks don't have the wiring for lights? Or are they all the same and just need the codes flashed.. ?
(I utilized the search feature :) )
IMO
1ATony
hemi
We always recommend matching feature to feature for easy of installation so that our customers do not run into any issues.
With that said, yes we have had piles of customers add features on and enable features that their truck didn't come with. I've read posts where adding features wasn't an issue, and I've also read of some dealers not being aware of some of the correct sales codes to add to unlock the other features.
These Ram trucks can get tricky when trying to enable some of the extra features. If trying to add options, you may want to consult with your local dealer first to see if it's something that they can do on your vehicle.
Regards,
Tony
matthewauclair
I have a 2011 ram 1500 with the small mirrors heat and power i installed tow mirrors they have power heat and puddle and turn signal is there a way to get the puddle and signal to work currently dont work
Jantelaw
