Tow package??
Kend0314
Rapid city sd
I just looked up my build sheet. It says I have a 7 Pin Wiring Harness
Trailer Tow w/4-Pin Connector Wiring
Heavy duty shocks. Does this indicate the standard tow package or just the trailer package? Thank you in advance
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
Depending on the tow package it could include a hitch receiver, factory brake controller, and tow mirrors.
The 7 pin is standard. That's not a tow package.
Kend0314
Kend0314
Rapid city sd
Ok, so what on my build list will indicate it’s a factory tow package?
randyr6
MD
cummins
Here's what is on my 2022 3500 Laramie single axle build sheet has on it
1) 7 pin wiring harness
2) Class V receiver Hitch
3) Trailer Tow w/.4 pin connector Wiring
4) Trailer Brake Control
5) Trailer Tow Mirrors
Not sure if items are because I have tow package, however I see no reason for any of them other than the hitch and 7 pin as standard equipment
turkeybird56
Central Texas
Here is what is on MY 19 Build Sheet:
NOTE: Has trailer towing functions, but not "Factory Tow", I had to have the OEM TT controls put in and flashed to ECU/BCM, so I have all the Tow information in my EVIC. TT and flash al done by Dealer prior to my Taking possession of vehicle. Listed in various areas in build sheet. I do have Heavy Duty Shocks all the way around and front/rear stabilizer bar also. Vehicle tows a 2,150 lb stock trailer fully loaded with hay no problem, basically 7,000 lbs. I do not have a WDH and do not use because my tow is local (under 15 mile round trip), just getting hay for Hossie. If I was traveling distance, be a WDH for sure. The HEMI tow well all day long, just may not pass every gas station it sees :anitoof:.
Electronic Stability Control
Traction Control
Electronic Roll Mitigation
Trailer Sway Damping
Class IV Receiver Hitch
Power-Folding Mirrors
