Towing a TT with no WDH
Doug Ram
Central NY, AKA Upstate NY
Eco Diesel _3.0
So I towed the new trailer without the spring bars attached. I like it a lot better. I have not ran it for a really long trip but it behaved just fine.
While I know I will get a lot of them...I would like to hear the opinions, I cannot see a reason to drag the extra weight anymore, well pending the longer trip.
Truck 2020 1500 Limited
Trailer 2021 Gulf Stream 19ERD about 3800 - 4000 loaded
The air suspension handles the load extremely well. No sag - the truck is level.
EDIT: I did use the WDH hitch just not the spring bars
I don't understand the big deal here. You're towing a light travel trailer with 400+ lbs of tongue weight. As long as you don't have any sway and you stay under Ram's tongue weight limit, you shouldn't need to bother with the WDH hitch -- at all! You save 50-100 lbs by using the conventional hitch rated for 5,000 lbs!
Farmer Fran
Farmer Fran
Earth
2020 Limited Loaded - Sold
Not "a big deal" this is a discussion forum, we are discussing.
Farmer Fran
Farmer Fran
Earth
Got the new Ball Receiver today. It weighs less than my old sway control bar.
ItemWeight (lbs)
Old Ball Receiver43
Spring Bars30
Sway Control Bar11
Total84
New Ball Receiver10
Weight savings74
runamuck
dfw
6.7 dsl
I used to tow my 6000# travel trailer without the bars but with the hitch the 6 miles down the freeway and back when I kept it in storage..didnt have any adverse effects at 65-70 but that's only a short distance. have never towed it without the bars on any trips. I park it at home now, so when we leave the house it is fully connected.
Cactusmonkey
Central Washington
Farmer Fran you have plenty of truck for the trailer for sure. I would strongly recommend that you use the hitch the way it was designed to be used. The spring bars as you call them can't add much weight to the whole set up. I don't pull my trailer to the street without using the bars.
Jerrybob
USA
We tow a 17ft Casita about 3000lbs with our 2019 Ram Tradesman......5.7...3.92....4x4.....tow package...the truck is rated to tow 11,000+.....we do not use a WDH....we have no sag.....have pulled in all conditions.....never a problem.....most of the time.....the truck doesn't know the trailer is back there.....we get great mileage....16 to 17 towing. My two cents.
Smokey613
Foley, AL
The ONLY way you are going to know the weight affects of the trailer on your truck is to get a CAT scale reading of your truck without the trailer and again with the trailer. Any thing else is speculation.
Farmer Fran
Farmer Fran
Earth
Just got back form a few hour round trip. No a single problem at all.
Remember my truck is 6100# and the trailer was (this time 3847#). I much prefer the non-spring bar approach. Towed way better.
Farmer Fran
Farmer Fran
Earth
The weight chart is above your post, I saved 74# and setup time ditching them.
Farmer Fran
Farmer Fran
Earth
I will post a picture of the 2 side by side as soon as my laziness subsides - it is overwhelming today
runamuck
dfw
6.7 dsl
this is one of those discussions where there are many acceptable answers because every situation is different. for example 30 years ago I had a full size blazer and towed all kinds of trailers with just a plain old hitch and had no problems..now I see we need a more high tech more complicated setup. kinda like in the 70's when we would drive thru the snow covered mountains on two lane roads in our one wheel drive sedan to go skiing but now I need 4wd with heated mirrors and all season tires to go to the same places.
Dodge 1500 4X4
Rochester, NY
The WDH is used for the spring bars or torsion bars (they aide in sway) say when a tractor trailer passes you or a gust of wind coming from nowhere, if your trailer and your life is worth chancing go for it.
Farmer Fran
Farmer Fran
Earth
It did just fine on 85 going ~68 mph, I passes trucks and trucks passed me. And the spring bars on my particular setup are for load balance. It has a separate sway control bar. When I had my big trailer the bars alone did just about nothing for sway.
ramffml
ramforum
I get the point but 30 years ago seat belts were optional, airbags non-existant, ABS was just gaining traction (ha!); would you say that we've made considerable advances in safety/performance since those days?
Also remember trucks back then were not rated to pull what they are now. The only way to get that kind of capability from a truck (max towing) these days is to use every bit of equipment possible; if you don't, please let me know when you're coming so I can book that day off ;)
Farmer Fran
Farmer Fran
Earth
I am towing ~1/3 of the max weight. My truck weighs almost 2x the trailer loaded.
ramffml
ramforum
I wasn't referring to you specifically; your weights look good. Ram says you need a WDH at >= 5000 pounds, you're under that so technically you don't need it.
Others might still want to run the bars though, because they also provide sway control.
Farmer Fran
Farmer Fran
Earth
I agree with this and your above statement.
