michael 13
- May 6, 2013
- 4
- 2
- 2013
- Hemi 5.7
Ok, I am confused about the tow capability charts for the '13 1500 quad cab Long Horn 4x4. Looking at the one for iPhone/iPad.
It makes sense, up until you calculate the final ratios of the first few gears, which give the 8spd/3.21 combo, a significantly higher overall ratio down low than the 6 sod and 3.92s, at the time when I would figure for the torque requirement should be at its peak, and a lower overall/final ratio for better mpg.
Why is the max tow rating so poor for the 8spd/3.21 combo?
Is the axle ratio, really more important than the overall ratio, or am I missing something. Before looking it up, I figured that the 8spd/3.21 combo, would at least be the equivalent of the 6spd with 3.92s. The overall ratio starts significantly higher, than the 6spd 3.92 combo.
3.55 and 3.92 capacities are within 50# of each other for everything else being equal.
Makes me also wonder, why the axle ratio of those sets is so similar as well.
I would have figured the limiting factor would move on to something like breaks with the overall/final ratio being expanded. More torque available to get things moving, and I was expecting better mpg during towing from the lower 8th gear ratio.
