Towing capabilities Ram 3500
timelinex
Phx
I just upgraded to a 2020 Ram 3500 Laramie 4x4 8' box and would love some clarification on towing terms. According to my sticker here are the stats:
GVWR: 12,300
GAWR Front: 6,000
GAWR Rear: 7,000
Payload: 4,213
Implied vehicle weight based on #s: 8,087
I was really surprised that nowhere on the vehicle does it show Max Towing Capacity or even GCWR.
According to the online RAM website, using my VIN, my max payload is 4,212 and max towing is 19,930.
1. Does the Max Tow Capacity seems right? Reason I ask is they don't have the correct payload, which puts into doubt how they come up with these numbers and how specific they are to my model/ 4212 vs 4213 payload... Not big difference, but it's either right or not and since some 5th wheels are 20k GVWR while the website gives me 19,930... a small difference could be the difference between legal or not. (although I'm not looking for a 20k one anyways)
I know that most people wouldn't recommend exceeding Max tow capacity numbers and I don't have plans on carrying anything over 20k... But I do want to know more for curiosities sake. I see alot of people saying that what ACTUALLY matters is not exceeding axle rating and tire rating, and that is why they don't even include max tow capacity and things like that on the stickers. Some questions about that.
2. Are the axle ratings referring to the GAWR's?
3. I know the only way to know weights for sure is getting the car weighed, which I will eventually. However what is the estimated percent of the weight that falls onto the rear axle on an 8ft bed? Reason I ask, is that I am guessing the process to figure out how much trailer I could carry would be to subtract that number from 7,000 and that is the pay pin weight of the 5th wheel/trailer I could carry.
Thanks!
392DevilDog
Glasgow, Pennsylvania
392 Hemi
You get the GCWR from the chart.
But since you have the number from the VIN look up...then you can do the math to see it
They found up the payload. Bet your VIN lookup says 4212.xx then rounded up to 4213 on the door jamb. The .xx is irrelevant
So 12300 minus 4213 is 8087 as you said. Which leads me to know you have a Cummins.
19930 plus the 8087 is 28017...hmm is 19930 exactly what it says.
So. 28300 is GCWR. And i am led to believe you have the SO Cummins and 68RFE transmission.
So 283 pounds is the confusion for me. Sometimes they give and allowance of 300lbs and hitch...but that does not add up either.
But otherwise. You did everything right.
28300 is you GCWR(found in the chart and verified by your numbers...~283lbs) and yes...axle ratings are referring to GAWR.
Everytime I load My truck and weigh it I get a different ratio of weight distribution. No way to guess it.
But yea..7000lbs is the number you do not want to exceed on the rear
OC455
Central NY
392DevilDog is correct with it....the 283lbs. part if odd though. But you are good. I have over 6k lbs of payload, but a low tow rating because of the 3.73 gear ratio, if I had the 4.10's I would have about another 3500lbs. of towing because the GCVWR would be 25000 instead of 21500.
Enjoy, you shouldn't have anything to worry about.
mikeynosikey444
