TPMS after a flat
30below
Did a search,but found noyhing about this.After having the left front tire repaired,the TPMS shows it has 1 lb and a red glow beside it.Does this sound like one of those put some miles on it while it relearns things?
quietpeen
2021 TRX
Hellcat
Yes go drive it for a little while and it should recognize the correct pressure
CostaRam
Costa Rica
If after 10-20 miles TPM is still not working,
then there is a problem with the sensor.
Mine relearned by it self after a 10 mile drive.
Chris
ColdCase
If all they did was repaired the flat and its the same sensor, then this sounds like the sensor was broken during the flat or repair. Did you have a blowout or slow leak, did you use a fix a flat can?
I'd drive it for a few miles. If it doesn't reset then sensor is bad. Most shops have a portable scanner and will check for free. They move the scanner close to all the wheel sensors and verify they are working.
30below
Thanks guys,it reset within a couple miles.
