TPMS question
LB3711
Trumbull, CT
3.6L V6
Im due to rotate my tires. Will the TPMS sensors swap on the display on my truck so it tell me the correct pressure for the correct tire? Or will the sensors will have to be swapped around. The 11's tell you pressure of each tire on the EVIC display.
Sent from my AT&T iPhone 4.
quietpeen
2021 TRX
Hellcat
Matt, I believe now a days they work trough proximity to that particular hub. No way would you have to take the tires off to swap sensors every rotation. I say that because on my last car i had a wheel that was flat, when I put it in the trunk and drove home my light never came on because the spare has a sensor also......but the sensor on the flat tire didn't register while in the trunk.
LB3711
LB3711
Trumbull, CT
3.6L V6
Hmm maybe. When I had a flat on the truck. Eventually that sensor went dead till it was remounted back on the truck.
I guess I'll find out today when I get my tires rotated and new lug nuts.
quietpeen
2021 TRX
Hellcat
why new lug nuts?
LB3711
LB3711
Trumbull, CT
3.6L V6
I hate the chrome cap lugs and I want chrome plated instead. Plus I have an issue with the front wheel lugs
quietpeen
2021 TRX
Hellcat
Yea the chrome cap lugs get screwed up quickly
Gray2010Ram
Cypress,TX
i wanna say the TPMS sensors will relearn there new location after driving for a bit that is if they are still like the 2010 model. i watch my tire pressure all the time and they always relearn their location right away
DENNY C.
Great question , what about when you run a separate set of tires / wheels, summer / winter , surly you don't need to move the sensors?
AustinB
Banned
San Diego, Left Coast
You don't have to swap anything out. Its like buying new wheels. Its doesn't matter. Rotate your tires or put a different tpms in it, wont change anything.
IMO
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
When I've rotated my tire's, I've never had a problem with the sensors. I did believe they relearn the new position.
Adam
butterscotch71
Central Ohio
2023 Limited Longhorn
I swap out wheels every winter and have never had an issue with the different TPMs being recognized
LB3711
LB3711
Trumbull, CT
3.6L V6
my issue still exists. I think the module is bad because swapping tires around it still the same ones that go out. I just ignore it now. I can check the pressures myself and I have a 2nd set of wheels for summer that don't have sensors in them and the light is on all the time. I wish it can be turned off permanently.
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
had mine rotated yesterday.no problems.they drove it around the block to make sure they are all functioning properly.
Saleen5150
