William Goodridge
- Aug 18, 2018
- 11
- 7
- Location
- British Columbia
- 2013
- 5.7 Hemi
2013 Ram 2500 SLT c/c 5.7L: 4 dashes displayed on TPMS screen. THe dashes all appeared at the same time, with TPMS light on constantly. Thought it odd that all the sensors would fail at same time. Checked pressures,(OK) changed receiver module with OEM, thought I would wait for winter tires which had new sensors installed Fall 2017 and worked last winter fine. Tire shop says sensors sending signal ...normal reset didn't work, hard delete with battery didn't work....hmmm factory pressures call for 60 front/75 rear with 60 in light load mode....are there two receiver modules?? ( one for the 60 f/70 rear) and the light load switch takes the 75 psi out of the mix?? getting pretty tired of this light!!
