TPMS reading wrong wheel/tire
dch703
Wisconsin
1988 and 1991
While driving today the TPMS light came on showing left rear tire at 65 and left front at 80. When I got home I figured out that the readings swapped and the display is showing the left rear tire in the left front position and vice versa. Anyone experience this issue and, if so, know what may be causing this?
Dan
2016 Ram 2500 4x4 quad cab
MADDOG
Living in a Firepit
Did you recently rotate your wheels & tires?
If not then I suspect the TPMS receiver module, located near the driver's side of the front bumper, may be glitched.
turkeybird56
Central Texas
^^^ this ^^^ Tire rotation. No more X swap, they just do same side front to rear/rear to front.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Dan
You have a 2016 correct? If you do like your sig says I would just replace them all
