TPMS sensors
Z-Rider
If one were to not have sensors installed on new wheels what is expected to happen?
Going to a higher psi tire on my '10 1500. Plan to delete the sensors at install. Will I only experience the light on the dash or will there be a repeating audible alarm?
Fill me in......
insanitize
I currently don't have sensors and I get a warning tone at startup and the evic says tire pressure monitor failure (or something like that) then the warning light flashes for a while. After this the light just stays on. I've been driving like this for a few months because I'm to lazy to pick up monitors and have them installed.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
I believe u can have the TPMS disabled in the PCM. Dealer can do it or perhaps an aftermarket tuner.
Z-Rider
Z-Rider
Dealer won't do it. Against Federal laws for them to disable it.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I know there are people thay put all 4 in a pvc pipe and install a tire valve on it and glue it shut air it up then put it under the back seat.
No lights and you can run what ever pressure you want to.
Never done it myself but have gave it some thought.
Z-Rider
Z-Rider
I've considered this but not sure how the truck would know which sensor is which.
Ratket
Arizona-
If it in fact works you would need to have the pressure over the maximum pressure setting - prolly what the rear is set for. In my case - over 80psi.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Iam not sure but you can you tube it and there are a few videos of people doing this.
DannyMK2
Long Island, NY
2015 Power Wagon
im pretty sure the sensors in these trucks need to rotate in order to read correctly, so i cant see the pipe thing working. i have seen it work in other vehicles though.
going to a tire that has a higher max psi doesnt mean your going to run it at max. maybe 5 psi more then what your OE tires were rated for, 10 psi tops. should not be any need for more then that, and that wont cause any issues with the tpms system.
Z-Rider
Z-Rider
I run load range E tires and to hit their weight capacity they are rated at 80psi
DannyMK2
Long Island, NY
2015 Power Wagon
there is no need to have anywhere near 80psi in your tires on a 1500. keep the sensors and you wont have to deal with the stupid chime/warning light.
