TPMS
Machete
I bought a set of used tires/rims and wasn't expecting the TPMS to work because they were off a Toyota. The plan was once replacing the tires was to install new TPMS. I was just expecting an error message for the time being
My digital display has a 2" wide vertical black line down the middle of my cluster after swapping to the aftermarket set. After going for a drive 3/4 sensors started reading and turns out the wheels were on a Ram before the Toyota
But the display comes and goes and when it does read properly you can still see the outline of the 2" line as it's slightly fuzzy or discoloured. Wondering is there anything I can do with the digital display save from replacing the sensors
