BlackRamHemi
- Joined
- Aug 14, 2013
- Posts
- 1,266
- Reaction score
- 557
- Location
- Edmonton Alberta Canada
- Ram Year
- 2010
- Engine
- Hemi 5.7L
We took a bone stock 2012 crew cab to the track in December of last year, and he went from a 15.1 with the stock intake to a 14.8 with the Vararam. This was done on the same night, on the same truck. This was also before the tuners were working properly, so he was on stock tuning. We also saw a consistent .1-.2 drop in ET on 3 different trucks running our 85mm throttle body...also on stock tuning.
Calling BS on you Matt,15.1 to 14.8 was more due to temp drop and humidity increasing by the time you had the swap done,and a .1 differance is virtually impossibble to document.
Ran my 4.7 with 1600 dollars worth of bolt-ons against a bone stock 4.7 and until i hit 4,000 rpm i didn't have any gains,and even after 4,000 i only had maybe a fender on him.
1600 bucks should of done more
Matt you were bragging to me about how you're on track to make $800,000 to a $1,000,000 this year,maybe rent a stock truck and some dyno time and spend some of that pile of money doing tests on a bone stock truck,starting with a tuner then adding the average bolt-ons piece by piece and giving us the honest answer on where the most value for money spent is available
BRH yes we know you've spent a ****load of money and have a fast truck,doesn't really apply to this post bud.
I had 5,000 invested in a 74 AMC Hornet and that included buying the car, that went corrected 11.3's at 120,that applies just about as much as your truck applies here.
It went faster then your truck for less then you spent on parts for your truck,and if you want to go even faster,buy a bike.
I also had $40,000 into a 68 Camaro that went 10.70's in the 80's,does that also apply
You are either forgetting or totally dismissing that BEFORE I ran my supercharger, (that's only been on for 6 weeks now)
I raced it HARD for over three years totally NA long before boosting it, likely accumulated over 300 track slips in that time.
I turned my truck from a stock 15.5 second brick to a 13.8 beast with the VERY same "BS" bolt on's you're bashing Matt over.
Intake, Exhaust,Tuner (The Big Three) got me a full second faster (14.5's) in my first season
and THAT was on heavier than stock 305/50R20 Terra Grapples.
Slapped on a set of sticky DR's got it into the 13's the very next year
with a Y pipe and a bored out TB (13.89/98.5 at 2500' DA) May 13/2011
Do you really think that's unreasonable for gains vs $ spent?
It's a freaking 5300lb + Truck, a 4x4 on huge tires/wheels
... not a light weight sports/muscle car.
Look at the Ram Fastest 4G track list and ask yourself,
How many at the top half of the list run a Stock Air Box, Stock Exhaust and No Tuner???
Now go to the other boards and check out their list
almost everyone who posts time slips has a mod list in their sig line.
NAdodge
DodgeTalk
RamFoumz
How many of those trucks run top tier bone stock, nada
EVERYONE has built their trucks starting with the same 3 mods you're knocking.
Just because you had bad luck with your choices, everyone else is wrong?
WTF Dude?!?!?
Maybe it's time to step up to a Hemi
if your little 4.7 is making you such a hater
