Traction control
jjrracing
HEMI 5.7
Winter is coming, therefor I would like to go out sliding around in my 14 RAM. My question is how do I disable my traction control completely!?
Im not to happy about removing the ABS fuse, I was wondering if there was a programming stroke I can do?
-John-
Statcher1
Kentucky
If you have a tuner you can disable it that way. Although you will have to remember to turn it off every time you start the truck
jstacey8
hiram maine
im in the same boat as you so let me know what you find out
dtru1222
Apparently there is someone on this forum who has the CMR software and they have figured out how to turn it off permanently. Thats what they claim at least.
First time I have heard of it and there are a couple who are confirming it.
With the tuner alone, you would have to turn it off every time you start the vehicle.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
You cannot permanently remove traction control without disabling it each time you get in the truck with a tuner. The easiest way is to pull the ABS fuse, but then you lose your speedometer, and your ABS, BRAKE, and Traction Control lights will be lit up on your dash.
14hemiexpress
6.4l
If you have 4wd press and hold traction control button for 10 seconds (in 4wd and it'll shut it down. Turns traction control and esp off.
14hemiexpress
6.4l
Pressing the traction control off has the same effect as doing it in the programmer on my truck. It will spin until you catch traction or let out...
If you start sliding esp tends to kick in. Atleast it does in my truck although I have 3.55 6 speed she don't spin much unless it's raining.
Reactions: jlb
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
That don't work for a 2012........it does kill like 60% of it, but once the tires are spinning and the rpm hits ~ 3300, the engine drops spark to limit rpm
jlb
MT
CTD
ABS fuse only lights the traction control, and ABS lights in mine, but it kills the traction control/ESP for sure!!
Lovin it!
TreyBear
2014 Ram 1500 Express night rider edition
ABS and traction control. Who needs this ****?
I've been stuck twice because the stupid traction control kicked in. The 5.7 hemi was gutless after that even with hypertech interceptor package. Someone please figure out how to completely disable this feature made for women
RLJ10X
Southern Indiana
I think what you want to turn off is the stability control.
If you don't have some form of "limited slip/Posi-Trac, get it.
I wish there was a way to turn off all the ads on this sight!
TreyBear
Yep. Hate the ads. I usually forget to hit the button to turn off till it's too late. Its goin to shop ASAP and I'm making rear end full time posi. Have a better launch anyways.
crazy_luck
Minnesota
Get rid of Internet Explorer and use Google Chrome with adblock plus and the ads are gone... :naughty:
As for the traction control - find an empty parking lot and learn what triggers it and how it reacts, and learn from it.
jag1886
Boise Id Gods country
Demi 5.7 S&B CAI, flowmaster merge collector, Gibson cat back, oil catch can, 87
Get a MAC I've never seen an ad on this sight.
Shambo
Which fuse my 011 has 2? Do I pull both?
L84DNR
Fort Bragg NC
I my 14 if I push the button to turn it off and hold it for about 30 seconds the light turns back off. Im not pushing it twice just push and hold.
Sent from my GT-N5110 using Tapatalk
Shambo
I had already tried that before and it does not work on my 011. I did find the thread and it said to pull J6 and that worked. So I'm going to hook up a switch.
