dwilliams566
I had the new TPMS sensors installed in my trailer tires and then did the process of setting the range and identifying the sensors where you drop 5 psi in each tire and the horn will beep when each sensor is recognized. My question is after i did that process and then towed the trailer the tire pressure still read 0 psi. Am i doing something wrong?
