Trailer TPMS sensors
dwilliams566
Vermont
I had the new TPMS sensors installed in my trailer tires and then did the process of setting the range and identifying the sensors where you drop 5 psi in each tire and the horn will beep when each sensor is recognized. My question is after i did that process and then towed the trailer the tire pressure still read 0 psi. Am i doing something wrong?
jejb
NW Arkansas
The work around for that is to go into the settings on the u5 system and select a different trailer, even one that is not setup at all. Then go back into settings and select the correct trailer. Still might take it a few minutes to show the tire pressures, but it always works for me. This is something I have to do every time I hook up the trailer with the TTPMS sensors.
