Tranny/Engine temp gauge
zeddy
Burbank, Ca
Hello everyone. First post here. I finally an owner of a brand new 2015 ram 2500 4x4 outdoorsman. Traded up from a 2005 titan.
I have a question. I've been looking for the digital tranny and engine temp in the cluster. I can't find it. My dad has a 1500 tradesman and he has it. I've looked in the dash menu but isn't there. I have the 8.4 u connect and the color display in the cluster. The manual shows it in the menu where u place the mgp/outside temp etc in whate ver corner u desire. Has everything but that. Any ideas?
Thanks in advance.
Ionicbrick
Are you talking about the two sort of semi-circle gauges on the left hand side of the main screen? If so you can assign those to whatever you want as well. I have mine on the trailer brake and MPG... I know it's in the menu, but can't remember off hand how I did it. I can look in my truck tomorrow if someone doesn't get to you first...
zeddy
zeddy
Burbank, Ca
The only semi circle I can get is the mpg.
If u can, I'd appreciate it.
Ratket
Arizona-
I always have mine so it displayes oil/tranny/colant and oil pressure. takes me 2 or 3 clicks to bring it up. I just always drive with it on that screen. Best way is going to be to play with it in the garage.
loveracing1988
Clarkston, MI
Read the quick start Guide that came with your truck. You will have to hit the up and down arrows to get to vehicle information and then cycle through that screen.
RoadDog66
Western MD
I was looking for this screen too this morning and couldn't find it. I wonder if you have to be in Tow/Haul mode or have a trailer connected to get it to show. I know when i pulled my trailer last week it was there.
RAMYOU
yes it was about 2 or 3 click to bring it up.
cc rider
Western NY
If we are talking about the same thing, you have to be in park for the setup. It tells you that. Keep scrolling down (or up) with the arrows on the sterring wheel. You will scroll through your odometers, fuel economy, tire psi etc., then you will see where u can change the display to your liking
Ratket
Arizona-
my low tire pressure light is on so when I start my truck it is always on the screen I then just hit the left arrow 2-3 times and the screen comes up, it doesn't matter if u have a trailer or tow haul turned on.
Ratket
Arizona-
if u want pm me, I will give u my cell# .. can just face time you while u are in the truck and walk you through it pretty easy. I know it took me a few weeks to get used to where all the settings are.
zeddy
zeddy
Burbank, Ca
Found it. I went to the tire pressure screen and cycled to the right. It was right in front of me. Thanks all.
Ionicbrick
If you're talking about these gauges next to the main selector window, then your vehicle must be in park. Scroll with the up and down arrows until you get to the screen setup and select that. Then scroll up and down until you get to "upper gauge" and "lower gauge". You can choose which gauge displays what setting there. In this same area you can also choose what is shown in the four corners of the main screen.
zeddy
zeddy
Burbank, Ca
Yeah, I would of liked it if I can get the tranny temp there instead of the middle. Oh well...
joshhhh
