Trans Fluid Leak
Slim328
Developed trans oil leak between trans and motor area, underside good coat oil?, where do I start to look for problem
PoMansRam
East Aurora NY
For sure it's ATF and not engine oil?
I'd start by cleaning the area as good as you can and try to pinpoint the source. Many times it may drip from the lowest point of the bellhousing, but the leak is up higher somewhere.
If it is just a coating and not dripping bad then I'd ignore it, likely a rear main seal, is a PITA to change. RfE so do you check level every so often? anyone ever drop tranny? happens when they reuse old seal to save money, or it can happen overtime.
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
After about a year of ownership, I was changing the oil on my 2015 and noticed a large area of "wet" (no dripping) on the transmission pan. At that time, there was online chatter about rear oil seals in the Cummins. The finger swipe test made it look like engine oil. Under warranty, to the dealer, it went.
I'm one of those lucky guys that has a good dealer with a good diesel guy. He told me he found two leaks, one was the engine oil pan gasket, the other was the transmission pan gasket. He repaired both and five years later it is bone dry down there.
I don't know if ignoring the "wet" is a good idea since it could get worst and present a major problem at the most inopportune time.
68Cudaconvert
