Find a local shop to do the labor and have them install your fluid, filters, pan...Hi,
What is the cost for changing trans fluid and filter?I have a 2015 8speed,and I am getting anywhere from $300 to $1,000.Thanks in advance.
Run away from any shop quoting you under $800. Your 3.6 is easy to change the fluid on,why not do it yourself.Lots of threads on here on how to change the pan /filter and fluid,and probably save yourself several hundred dollars,and you'll know it's been done properlyHi,
Thank you.Run away from any shop quoting you under $800. Your 3.6 is easy to change the fluid on,why not do it yourself.Lots of threads on here on how to change the pan /filter and fluid,and probably save yourself several hundred dollars,and you'll know it's been done properly
Ignore the genius above,he has issues with doing things properlyThank you.
Trans needs to be level, not the vehicleCan be in and out in a couple hours, with time for a beer or two while things drip.
Drop the pan, replace pan/filter (PPE or OEM), fill with Maxlife or OEM fluid with the vehicle level (make Wild One cringe) and you're golden.
The dealers I have talked to confirm they level the vehicle during a service. If you wanna level the trans knock yourself out... more power to ya.Trans needs to be level, not the vehicle
If you haven't seen this sheet,these are the ZF instructions that come with a "brand new" truck specific 8 speed when bought from the dealer.The first highlighted paragraph is very important as you can tell by the way it's highlighted.Also the ideal checking temp is between 100F and 105F,the 122 is the max checking temp,not the ideal checking temp.Thank you.
