trans service
JMikk
5.2L 318
im planning to flush my trans and change the filter, biggest question is do i have to adjust the bands or not. I know the dealer would do that but id rather do the service myself and replace other needed parts.
Merc225hp
NA
truck
gas
Do not FLUSH the trans just change the fluid, when most adjust the bands its not long after the tranny fails so up to you.
J
JMikk
5.2L 318
Alright so just drain the pan and refill, nothing else
CVX20
Ont,Ca.
2019 Classic Express
I agree about flushing.That usually just stirs up the **** that's in there,but I doubt a properly done band adjustment is going to make it fail anytime soon.If someones trans failed right after an adjustment then obviously it wasn't done right or it was a huge coincidence.
dapepper9
Iowa/Nebraska Border
5.9L V8
I talked personally with the owner of CascadeTransmissionParts.com and he said that the factory specs are too tight and cause extra wear and can create problems. He suggested 2.5 turns backing off on the front and 4 on the rear
jsmith
Good info, when it's time for me to do it again I'll try those specs
CVX20
Ont,Ca.
I guess it's possible,but you'd think the manufacturers would know how to adjust their own tranny's.Usually they would figure something like that out after a year or so and then put out a PSB to change the adjustment spec. if it really was an issue.
