Transmission cooler line replacement help
Jeff99gsx
Ohio
4.7 v8
So I have a 2009 5.7 Ram and the transmission line came off at the cooler. I ordered a new line set but the BLOCK that bolts to the cooler is what broke.
Looks like there should be an aluminum block that holds the cooler lines into the cooler body. It seems like it corroded away.
Does anyone have pics of how this piece should actually look without all the rust and corrosion?
Or can anyone help me find that part number or what piece I need to order. Thanks in advance. Here is a pic.
Might be time to look into plumbing a seperate stand alone transmission cooler into place.
