Transmission Fluid Line Leaking
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
My truck is a 2001 4x4 SLT Larmie with an automatic tranny and 86,000 miles. I just noticed my lower flexible tranny line running into my radiator is leaking( leaked about a 3" circle in about 24hrs). I believe it is the check value that is leaking but please see my attached pics(green arrows point to what I believe to be leaking). Should I do the check value deletion mod? If so please attach a good url of a website that has a good write up on it. Thanks guys!
NOTE: the green arrow is pointing to the part of the hose that connects into the radiator
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Or does anyone know the part number and where i can find it so I can just replace it? Would be much appreciated!
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
No one can help..?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
You should consider doing the check valve delete instead of trying to just replace the line with an OEM line.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I was considering doing the check value delete mod untill I read a post that said that some guy did it and he ended up putting the check value back on because it can be dangerous if the torque converter does get tranny fluid in it..
Also I noticed from the url that magic sent me, that my check value isn't the one leaking, it is the tranny cooler line below the check value line...
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Also after reading the first post of the check value delete mod and looking at the pics many times I noticed that his return line (line with the check value) is coming directly from the bottom of his radiator. I'll get pics of mine in the morning but I don't think my does that... I believe that my 2 flexible tubes go into rigid tubing(just like his) but then pass by the radiator on the passenger side and up and into the auxiliary cooler that is infront of my radiator
LaurenMagnum360
Illinois
360 V8
I plummed mine to go thru the radiator as well as an external cooler. The reason I did it that way is I live in ilinois, and its not uncommon for it to hit -20 in the mornings when I warm up the truck. So the radiator will actually warm the transmission fluid up, because it can damage the transmission if it's too cold.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I love in Utah so that is was is making me a little hesitant to do the check value delete because it can get in the negitives in the winter here
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
After further inspection it, I now know that the check value line isn't the one that is leaking. It is the one that is coming from the tranny into the axillary radiator(atleast I thing that is the one from the tranny). Please s3 new pic with green arrow. It is leaking very slightly.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Any thoughts are appreciated!
Ramunit
Is it not simple to just replace the line with connectors? It looks to be about a foot long.
rowdyram
magnum 5.9
Cut the compression fitting sleeves off replace that section with the appropriate rubber line and worm drive clamps
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I think I am going to do as said above.. cut the flexible section out by cutting a small piece of the metal tube on each side and put a new hose on it and clamp it down.. should I try to flare the ends of the metal pipe or will a simple worm clamp or two on each side hold it?
How much pressure will the line receive?
KAKA
