transmission goin out on my 2005 ram 1500
avp12304
4.7, 5.9 Cummins
hey guys, so my question is, what transmission is in my automatic 2wd ram 1500 SLT 4.7L, or how do I check? and what all years is compatable so I can start searching for a new one. thank you!
gtomike60
Milford,Mass
5.7L HEMI
It should be a 545RFE
If you're getting one from a salvage yard,they'll know the correct one to get and what years will fit
HemiLonestar
Navy Badge Coast Guard
MD
Any 45/545RFE from 1999 to about 2012 will work. Whatever computer you have is how the trans will act. The only difference between a 45 & 545 is programming; physically the same trans. For example, you have a 05 545RFE. You could take the 45RFE from a 2002 or earlier (only uses one OD gear), plug it into your vehicle it will run just like your original trans (with two OD gears).
