SavannahRam
- Oct 22, 2016
- 8
- 0
- 2007
- 3.7
Hey fellas. 2007 Ram 1500 5.7
Before replacing tranny: Mysterious one day the tranny filter 'broke' off while I was driving. All of the sudden it would barely move at all. After limping home we and the mechanic dropped the pan and found this out. We placed and redealed and it was good to go. We pretty much agreed that something that tramatic put a time limit on the tranny. Im an independant distributor and put a ton of miles on it anyway. So, from that point foward every now and then Id start it and it wouldnt have alot of power in first gear. it wouldnt roll foward like it should and would rev real high until getting past first. Eventually it would hard shift now and then as well. Eventually the tranny temp light started coming on and one day it failed. I took it to the shop and they of course said the tranny was done and that I had a glod on my treanny cooler and radiator.
Got it replaced with a used tranny (I aint rich) I just got it back about a week ago. When I first for it back I noticed on the Dash all of the gears are selected until I put in into gear. Ive read a few threads where that is the case and the truck wouldnt start ... well mine started no problem and drove fine. It downshirts hard into first from highspeed sometimes, but other than that drove great.
Then all of the sudden the check engine light came on today and I had no power in first like before the replacement ... and all gears stay selected on the dash no matter if its in gear or not. My buddy took it to get the code from the light and it was p0846
Transmission Fluid Pressure Sensor/Switch "B" Circuit Range/Performance
it says replace shift silenoid but I wanted to post about it and get opinions cos of what the dash gear selector is doing .... thanks for any help.
