Transmission slip
damyzz
Canada
Help,don’t want to go to dealership just yet,2012 ram 1500 4.7 transmission slipping when trying to go into passing gear
Does it slip when you drive in tow haul mode?
D
damyzz
Canada
Never tried that but I will,but more details are...floor it and it seems to come out of gear,when the rpm come back down,it seems to pop int gear.can drive it and will get up to highway speed,but as soon as I step on it,rpm go up like it’s out of gear
First check fluid, for condition and smell if it is fresh or burnt, and check the level on dip stick. How long ago was trans serviced?
Lot's of reasons for transmission slipping, the question is what route to take. Clutches are the first thought, but that is worst case news so what difference does it make? If you are dropping the transmission anyhow, you are rebuilding it anyhow. Just ask a local mechanic what it would be for a rebuilt rfe with new valve body and solenoid.
It is possible there is a leak in VB causing issue, or SP and causing issue, but there isn't a guarantee on it.
Try tow haul, if that works it might be VB. If the VB is leaking, the extra pressure of TH might just make the slipping go away, if it is clutch packs that wont matter.
