Nick Redmond
Easiest way to check is to turn the AC on, the fan should turn on shortly after.
Are you tuned at all? The fan won't come on unless the coolant temp gets to 220 with the AC off on the stock tune.
Personally I would mount a secondary cooler below the factory cooler which is the top 1/3 of the condenser/trans cooler assembly, and have the return line from the factory cooler feed the inlet of the secondary cooler. That way you get double the cooling. Only thing to watch out for is reducing fluid flow too much so make sure it's a high flow cooler or a relatively small cooler. You can get one with a fan but that's more work to install, more to go wrong in the future, etc.
Even with your setup, 190 is way too hot for normal driving. Something is definitely impeding fluid cooling because I towed around 4000lbs up the Ike Gauntlet with the truck loaded up as well and my trans hit 175 for about 5 mins before cooling down to 140 pretty quick when the road leveled out.
Keep us updated[emoji106]
I do have a diablo trinity T2 tuner on it I’m running the 87 octane tune I’ve also tried changing the temp where the fan comes on and it will delay it getting hot but will eventually get to 190-210 with about 1hr of driving. Another stupid question I have is I was going to order a deeper pan so I got the number off the trans and looked it up to make sure I get the right pan and from the sticker on the transmission it’s showing it’s a 66rfe. I’m the second owner and all I know about the previous owner is it was custom ordered from the factory. So I’m wondering if it came from the factory like that or if it’s been swapped or if its just not pulling up right. I know the 66rfe was in some 2500 trucks but never heard of one being in a 1500
